Hi!
I have question. Some year ago AI has new function for simplification - ENVELOPE
After simplification (complex sub-assembly i replace to envelope) i want export simplified model to STEP format, but envelope don't export....
How can i export simplified model to another software?
Solved by Fouad-l. Go to Solution.
Hi @oleg_inv.
I usually use Shrinkwrap tool to simplify complex assemblies for external sharing. It works very good and has the possibility to control the level of detail you want to show by including/exluding parts/features, deleting features by size, using different styles for the resulting part ..etc . Once yo have the shrinkwrap part its very easy to save it as a step file and send it.
more info : https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
