Export Autodesk Inventor To ANSYS (step/iges) As Solid Body Instead of Surface
Message 1 of 9
Good day.
I'm trying to export a part model from Inventor to ANSYS for FEA. Client prefer to use ANSYS for FEA. Problem is that ANSYS recognized the file as Surface body instead Solid body.
I tried almost all file formats (iges, step, parasolid, stl, sat) but still, same problem.
Please help thanks!!
kelly.young has embedded your image and edited your subject line for clarity: Export Autodesk Invetor to ANSYS (step/iges proble)
Replies (8)
Message 2 of 9
KevinLi-Autodesk
Hi jester.gacusan,
Is your Inventor part model solid or surface ?
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 3 of 9
solid part. i don't know what is the problem.
Message 4 of 9
KevinLi-Autodesk
If geometry in the model is a solid and have no geometry errors, Inventor should export it to be "solid" via STEP/IGES.
What's your Inventor version ? May you send the model to me via Hongyuan.Li@autodesk.com for further investigation ? You can also check if there are some options in ANSYS that convert it to surface when open the STEP file.
Kevin-Hongyuan Li
www.autodesk.com
Message 5 of 9
Hi Kevin,
I have a similar problem when I import the model from Inventor Professional 2018 to Ansys 17.2.
I have 449 parts, 449 bodies.
Can you help me?
Thank you!
Message 6 of 9
johnsonshiue
Hi! Do you mind elaborating the issue better? Are you getting bad bodies in ANSYS? Or, are you hoping to get one solid instead of many? Could you start a new thread and share the files here? There should be a logical reason behind the behavior.
Many thanks!
Software Test Engineer
Message 7 of 9
Hi!
In Inventor I made separate structural elements and after that I assembly them into one whole. A good model was created in Inventor. On this model, in Ansys, I have to do a Static Analysis.
The problem appears when I convert the construction from Inventor to Ansys.
Convert is achieved:
(In Inventor) File>Export>CAD Format STEP
(In Ansys) Geometry>Replace Geometry>Browse STEP File
In this way I did not get a good geometry in Ansys. My construction should only consist of 89 solid bodies where I need to set up connections.
In Ansys appear 229 solid bodies and 220 surface bodies. Surface Bodies are counted as place of welds and even a surface body is considered to be one a complete solid body from Inventor. I do not understand why this body Ansys counts as surfaces.
In Attachment I send photos:
  • Model in Inventor
  • Model in Ansys
  • Surface Bodies in Ansys
Thanks for help!
Surface Bodies in Ansys.pngConstruction in Ansys.pngConstruction in Inventor.png
kelly.young has embedded your images for clarity.
Message 8 of 9
I have to solve this problem as soon as possible because it is a project that is of great importance. Do you have any solution?
Thank you in advance for the information!
Message 9 of 9
johnsonshiue
Hi! The information you provided so far is not actionable. Translation issues can go both way. It is possible Inventor writes out bad geometry in STEP file. It is also entirely possible that ANSYS misinterprets good geometry from Inventor. You can do a quick test. Close all the files in Inventor and import the same STEP file back to Inventor. Do you see good geometry? If yes, the issue is likely in ANSYS. Have you tried other neutral file format like SAT?
Many thanks!
