Export 3D Pdf, empty file
CGVJM6DF
CGVJM6DF
Hi Everybody,
I am using Inventor 2024 but for some reason I can't export to an 3D Pdf.
Actually I can but the 3D Pdf file it is empty!
What can be the reason?
YannickEnrico
I guess it goes back to your export settings
Did you remember to choose at least one design view rep? Does the one you chose have parts? Or is it empty?
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
CGVJM6DF
Hi @YannickEnrico
I have only "Primary" and "Default", but whatever I choose it is empty!
YannickEnrico
What program are you opening the resultant file in?
in my experience, you have to let Adobe Reader trust the document to enable it.
The screenshot is in Danish, but I'm sure you get what I'm trying to convey.
Edit: there's also a right click in the 3D part to enable it;
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
CGVJM6DF
Mange tak @YannickEnrico
It is ok in Danish to...
Dette fortæller mig meget, at jeg skal lade Adobe Reader stole på, at dokumentet aktiverer det. 😋
