EXPLODED VIEWS WITH MODEL STATES
SECOJOSE
Message 1 of 14
SECOJOSE
Im creating drawings for each model state of an assembly, and each drawing will contain an exploded view. How do you change the parts model state an exploded view?
Replies (13)
Message 2 of 14
mluterman
You can't do that within the model state of an assembly (.iam). You have to use Presentation File (.ipn) to associate your exploded views to each model state of your assembly. See this link:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-F4F6F136-003C-4D1C-9EC1-81102BADC867
Message 3 of 14
SECOJOSE
I guess the question im trying to ask is, can you use the same .ipn file for multiple model states, or do you have to make a separate .ipn file for each model state?
Message 4 of 14
James_Willo
Hi Joe, to include other model states you need to right click and create a new scene. You can select the model state in the Insert dialogue that opens.
James W
Inventor UX Designer
Message 5 of 14
SECOJOSE
James, that's exactly what I needed. A follow up question though, in a drawing view of the presentation, how do you change the view's scene its representing?
Message 6 of 14
James_Willo
Double click the view and you should have a dropdown.
James W
Message 7 of 14
SECOJOSE
The drop down is greyed out and locked. Is there a setting that needs to be changed?
In the presentation, when trying to change the Representation, the Model State is also greyed out and locked:
Message 8 of 14
James_Willo
Yes, you cannot change the model state of a presentation scene.
Bizarrely you don't seem to be able to change the scene once placed in a drawing. I didn't know this was the case. I will find out if this is a bug.
James W
Message 9 of 14
James_Willo
Edited reply:
We have found this same behaviour in code going back 9 years. I don't know why you cannot change it.
Thanks for reporting it, we are looking into if there's a reason why.
James W
Message 10 of 14
SECOJOSE
Thank you for your response. Let me know if you need anything additional information on the part or drawing.
Message 11 of 14
James_Willo
We are tracking this internally as INVGEN-77376
James W
Message 12 of 14
ssatoN9PWG
Observer
Observer
IT'S BEEN A YEAR. ANY UPDATE?
Message 13 of 14
johnsonshiue
Hi! I just checked INVGEN-77376. There isn't much progress on that. It is still not resolved. If you want to escalate the issue, please contact Autodesk Product Support and mention the defect ID, INVGEN-77376.
Many thanks!
Software Test Engineer
Message 14 of 14
James_Willo
Hi, in Inventor 2026 it IS possible to change model state in the presentation environment, but you still cannot change it in the drawing environment. .
James W
