Exploded view from stp file
Hi everyone,
I have a problem with making exploded view.
I know that it's possible to make it from iam. file but how to make it only having stp. file?
I_Forge_KC
If the STEP is an assembly file, you can open it in the assembly environment, save it, and then make the presentation.
If the STEP is a multi-body part file, you'll need to create components out of the bodies first. To do this, head to the Manage tab, Make Components, and then follow the prompts.
K. Cornett
Generative Design Consultant / Trainer
Xun.Zhang
Yeah, please import the step file and save as assembly or make multi-body part to an assembly, create a new ipn file for the assembly file and make any explode view in the presentation environment as you want.
Hope it helps!
Xun
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous were you able to figure out how to use the make components and save as an assembly?
If you are having troubles you can use Pack & Go to share the files or record a screencast of what you are experiencing.
Please select the Accept as Solution button if a post solves your issue or answers your question.
