Hello,,
Does anybody have experience with Autodesk Inventor 2023 running on Dell 3581 Mobile Workstation with NVidia RTX A1000 6GB ?
Thanks in advance,
Caio Godoi
Voith
Hi, please try the unofficial InvMark
https://forums.autodesk.com/t5/inventor-forum/invmark-by-tfi-amp-cadac-inventor-performance-hardware...
If you intended to have links in your post it didn't work.
Can you post the specs for this computer? Inventor runs best with a fast CPU and 32 GB RAM or more. 1 TB solid state drive is helpful. The graphics card looks fine.
But it depends a lot on what kind of work you'll be doing with Inventor. If your work is small assemblies, a few hundred simple parts (mostly), then you don't need nearly so much power. If you're doing a lot of complex parts, ten-thousand-part assemblies, rendering of same, FEA analysis, then you'll need as much RAM as possible and the fastest CPU you can afford.
Sam B
Inventor Pro 2025.0.1 | Windows 11 Home 23H2
