You can accomplish this as follows:
- Edit the sketch you wish to turn into a symbol.
- Select everything that you wish to be part of the symbol.
- RMB and select COPY
- Open your template file
- RMB on SKETCHED SYMBOLS in the browser and select DEFINE NEW SYMBOL
- Paste what you have copied into the sketch
- Save the new symbol with your desired name.
- Save your template file.
Seems tedious, but it has worked for us in the past.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
