error
error
error
Hi every body,
The attached is a file for a sketch. I wanted to do an extrusion for to it but I failed. May any body with great thanks, tell me where is my error? Indded nowing the errors is a great think to avoide other things that happenes during the work
Regards
atajabbas
Inventor 2016
mdavis22569
What version are you in ..
I ended up redrawing it
I made a square ... did the outside dim's, fillet on the edges ...
There are a few other ways to do it ..
Mike Davis
johnsonshiue
Hi! There are multiple issues with this sketch. First, there are overlapping line segments at where dimension 310 is at. Also there are duplicate dimensions. One of the 310s needs to be deleted. Also the 280 dimension is not helpful. After that, I ran through Sketch Doctor and it helped finding the missing coincident constraint and a tangent constraint. Now the sketch can be extruded again.
Many thanks!
Software Test Engineer
mdavis22569
Way to much work for what the end result
Mike
Mike Davis
