Error using Grill Tool
khushank.ks
khushank.ks
I am trying to make a grill out of a solid with a thickness of 0.05mm using the 'Rib' command.
The width and the depth of the ribs is also 0.05mm. However, I keep getting an error saying '... did not produce meaningful results. Try with different inputs'.
I am using Inventor 2018 Pro and the configuration of my pc is pretty nice.
Please suggest a solution. Thanks in advance. Part file is attached.
SBix26
Before we get to the Grill tool: you must constrain your sketches, particularly the first one.  Currently it is a rectangle with no dimensions at all, and not constrained to the origin.  One little accidental nudge, and a complex grill feature like this might fail spectacularly.
Now, for the grill itself.  After the same failure (I assume) that you experienced, I made the boundary sketch much shorter so as to work with fewer sketch lines, just to see if it could work.  I was able to get the grill feature to work in this smaller area, as long as I left out one specific line (see below, the red one).  I have no idea what it is about this line that is different from the others, but when I include it in the Rib profile selection, the Grill feature fails; when I exclude it, the feature works.  The attached file is 2018 format.
Sam B
Inventor Pro 2020.0 | Windows 7 SP1
LinkedIn
WHolzwarth
Similar as Sam, I ran into troubles with Inventor's grill feature, and I didn't find an all-around way in Inventor.
I did some pingpong with STEPOut, opening in Rhino, extruding all curves to surfaces in a single operation, thickening and ending in more than 1000 solids.
Boolean unions seem to be not good in Rhino, so after that STEP transfer back to Inventor, and deriving to a simple body. After that cleaning up the result with a last STEP (attached)
Walter Holzwarth
khushank.ks
Thanks for replying. This is exactly the grill i was trying to achieve.
But still this doesn't solve my problem as i have several other similar files to convert into grills.
WHolzwarth
Generally, this could have been done in Fusion 360, using the Web command.
Smiley Frustrated But sad to see, that even a very simple test was failing.
Walter Holzwarth
