Error: This command is not valid for the application or document projects
I get the following message when trying to edit the vba and save it.
What Am I doing wrong? (so to speak)
mcgyvr
https://forums.autodesk.com/t5/inventor-customization/this-command-is-not-valid-for-the-application-...
If that doesn't help providing more detail..
What you are doing exactly? What are you editing? What code did you change?
How did you go about that?
etc... would likely be beneficial..
Sergio.D.Suárez
Hi, Could you share your line to see if it is possible to find the error?
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
