error loading segment amrxsegment in database
er.rohanmore
er.rohanmore
Getting the above error while opening the drawing file.
CCarreiras
Hi!
 Maybe you have some iLogic rules in the file that need to be fixed or needs the be updated with the 3d model.
Open the 3D model first to test.
CCarreiras
jacob.galle
So the file being corrupted doesn't explain this...
I am able to open the file, NMR.XFC-000192, from vault. I cleared my C: drive to see if it would download from vault, which obviously did.  When I open any file with the model (192.iam) in it, i get these errors about 100 times, then the model opens. At that point if I try to do anything in the model, instant crash, sometimes without even pulling up the crash report window. 
johnsonshiue
Hi! The file is indeed corrupted. Though it opens, likely something disastrous will happen sooner or later. Unfortunately, this type of corruption cannot be repaired. You will need to go to Vault and find the prior healthy version of the file.
Many thanks!
Software Test Engineer
