Error information in shell command
Gwennberg
Gwennberg
Hi! Why can’t you get more exact information about what has went wrong in this command due to changed thickness? Some visually indication where the conflict exists should be great.
/GW
JDMather
Can  you attach the file here?
Gwennberg
Hi
Sorry, I?m not not able to let this part file out of the company.
It would be great if the error command could show me where in the model my error is.
BR/Goran
PaulMunford
When you see an error, expand the text until you see a note in red. Click on the note, and the error will be highlighted in the graphics window:
'When the message dialog box displays an error list, the design failures display in red underlined text. If you select a design failure message in the list, the location of the failure is highlighted in the graphics window.'
https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-69196418-14DF-4128-B4F3-581FFC994C78
Paul Munford
Technical Onboarding Architect
Linkedin
dan_inv09
I don't think that the shell error messages are anywhere near that helpful.
