I have this attached Sketch, and when I try to add even a simple line into it, I get this below error:
Problems occurred while solving sketch. Use Edit Sketch to change sketch geometry or constraints.
Dimension could not be solved. Change its value or remove some sketch constraints to allow the dimension to be solved.
Dimension could not be solved. Change its value or remove some sketch constraints to allow the dimension to be solved. [Repeated several times]
What is going on here?
Also, when I was creating this Sketch, I saw that when I used 'Mirror', a few lines used to turn blue even though the Sketch was 'Fully Constrained'. The lines turned back to black when I changed a few dimensions and they remained black when I changed those dimensions back to their original values.
Overall, Inventor seemed to behave a bit unpredictably when I work on this Sketch.
The overall dimension of this Sketch is in the range of 100 meter by 70 meters. Could it be because we are supposed to be working only on small parts (a few meters maximum, maybe) and not tens or hundreds of meters? This is a rail track layout. Would you recommend some other approach or another method for defining the layout of a rail track system?
Thank you!
