error in inventor 2018 symbols
hello
im install inventor  and inventor view 2018 an  i try to use files created in inventor 2013 but the symbols of anguls are missing.
i need help
regards.
johnsonshiue
Hi! This should work. Could you share an example exhibiting the behavior?
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
If you can attach your files, create a screencast of the behavior, or take a screenshot of what you are experiencing we will be able to point you in the right direction!
