Hi, I'm relatively new to Inventor, but have managed to make multiple 3D drawings which could be imported in the STEP format to COMSOL 5.1. However, as of today, it seems that my Inventor has lost its ability to do so for drawings of small dimensions.
Previously, I could draw a 500 micron radius quarter-circle and then extrude it by a few microns to generate a 3D solid. This could then be saved as a STEP file, which could be imported into COMSOL with no issues.
Now, I have tried multiple solids of small dimensions, but they all resulted in COMSOL giving me an Internal error code: 900 during import. A solid with big dimensions, such as a 0.125" x 0.188" rectangle extruded by 1", would have no such issue.
To check if this problem arose because of COMSOL, I tried to import my previously drawn solids, and there were no issues. I also could modify the dimensions within my previously drawn solids, and save it as another STEP file. This way, COMSOL would be able to import it with no problems.
Based on what I did, I believe this to be an issue with COMSOL, most likely with an automatic update or patch in September. I have tried this with both Inventor 2017 and Inventor 2016, but the same problems appeared for both cases. Does anyone know of a way to rectify this issue, or is anyone else facing the same problem?
Thank you.
