Error 0x80040155 in iLogic
PiazzaD
PiazzaD
Hello, we wrote an iLogic rule reading an embedded Excel file.The rule works fine on every PC we tested except one.
This PC W7x64 with IV2015 up to date and Office 2013 returns the following iLogic error:
System.Runtime.InteropServices.COMException (0x80040155): Classe non registrata. (Eccezione da HRESULT: 0x80040155)
   in Microsoft.Office.Interop.Excel.ApplicationClass.get_LanguageSettings()
   in iLogic.GoExcel.SetCurrentSheet(String fileName, String sheetName)
   in LmiRuleScript.Main()
   in Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   in iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Already reinstalled inventor and Office but no way. Anyone experiencing the same issue?
Thank you,
Daniele
Mark.Lancaster
Do the other PCs have Office 2013?   On this machine have you at least launched excel?
Mark Lancaster
PiazzaD
We tested on several PC with 2013 and no problems. Excel on that PC is working fine. I just disassembled the iLogic code and at that point is calling the Excel Interop. Probably something wrong with the PIA. The point is in Excel 2013 PIA is embedded in the Office setup. No more available as a stand alone installer.
