Equation of a spline
Is it possible for inventor to give the equation of a spline? I have points constrained in specific locations x&y, put a spline through them and now I am trying to determine the equation of the spline inventor produced.
Cadmanto
Welcome to the forum.
You can export the points to an excel spread sheet.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
See this other thread that might help you.
https://forums.autodesk.com/t5/inventor-forum/equation-curves/td-p/3764413
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! Unfortunately, we cannot provide the equations generating the spline. It is considered proprietary.
Many thanks!
Software Test Engineer
