Equation curve irregular at parameter value 0
elanzel
Message 1 of 22
elanzel
I'm trying to create the involute of a circle using an equation curve.  The equation works fine except when tmin = 0.  I get a error that says the curve is irregular at parameter value 0.000000 (see below).  Has anyone else seen this error and/or found a solution to it?
Replies (21)
Message 2 of 22
johnsonshiue
Hi! I have seen this behavior before. The error is due to the fact that there is a singularity at 0. The workaround is to set the lower bound to a small non-zero value like 0.00001.
In the meantime, I will take a look at the equation closer and see if the singularity is indeed unrepresentable.
Many thanks!
Software Test Engineer
Message 3 of 22
ravikmb5
Equation Curve For Involute
Sometimes it works
sometimes it will not
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 4 of 22
johnsonshiue
Hi! I have plugged in the formula and range to create a EDC. Indeed, tmin = 0 is possibly causing geometric problem to create a valid sketch curve. I am able to get past the error by setting timin = 0.0004. I can forward it to development and see if there is anything we can improve.
Many thanks for reporting!
Message 5 of 22
johnsonshiue
Hi! The equation in the image is a bit too small for me to read. Could you post the file here or send it to me directly (johnson.shiue@autodesk.com)?
Many thanks!
Message 6 of 22
elanzel
Thank you for the response.  A small tmin value will work for what I'm trying to do but it is kind of frustrating since I could do this is solidworks with no problem.
Message 7 of 22
ravikmb5
its work in inventor as well
basically in solidworks and pro-e the equation entered in
x(t) and y(t) is always in radians
but in inventor t value will be either in degrees or radians based on part units
attached is the model which is made in Inventor 2015
And major problem with Inventor tmin wont start at 0
tmin to be kept at 0.004
Ravi Kumar MB,
Message 8 of 22
There is no singularity in this equation for t=0. As you can see from the equation there is no division and thus no division by zero is possible. I have found the smallest value to avoid the false positive error is 0.0000115 ul. Very disappointing from a very expensive program.
Message 9 of 22
johnsonshiue
Hi! I am very sorry that this particular case does not work as it should. Indeed, this is not a singularity issue. This is about how 2D/3D sketch handles 2nd or 3rd derivative. We have been investigating a solution but so far, we still do not have a safe solution yet. If there is any progress, I will let you know.
Many thanks!
Message 10 of 22
I'm having the same issues as the OP. This in Inventor HSM Pro 2016 - Student Version.
Is there any development on this..?
Message 11 of 22
johnsonshiue
Hi! Is your equation the exact same as the OP's? If not, could you post the file here or send it to me directly? I would like to understand the behavior better since your issue may not be the same as the OP's. Thanks!
Message 12 of 22
It is, actually.
I'm only now starting to seriously play with Inventor and trying to find best practices and such. I've had a lot of time on both Creo Parametric and Solidworks at school so I'm still finding my feet here...
Message 13 of 22
drdlboyd
I am having a similar problem when attempting to create an Archimedean spiral.
This works:
Yet this does not:
Message 14 of 22
JDMather
What is the tolerance of your manufacturing process for this part?
Message 15 of 22
johnsonshiue
Hi! May I ask what release of Inventor are you using?
Many thanks!
Message 16 of 22
drdlboyd
The part will be 3D printed in ceramic so we're hoping for maybe a couple hudredths of a mm on wall thicknesses of about 0.75 mm.  The problem is that any value less than .0100000000000000019 causes the error.  This means that I cannot get spacing between successive turnings to be less than about 3.6 mm.
Message 17 of 22
drdlboyd
Message 18 of 22
johnsonshiue
Hi! For this case, you might consider starting t from a non-zero value like 0.000001 ul. It should allow the curve to be created. There is a known problem on handling the derivatives at zero. The issue has been resolved on Inventor 2017.
Many thanks!
Message 19 of 22
drdlboyd
The problem still occurs even at much larger values of t.  Here I started t at 1 and it occured for r(t)=t*0.009 or less.
Message 20 of 22
I am having this problem also.I am trying to put in an equation for an ellipse parametrically as x=0.1*cos(t), y=0.2*sin(t), 0<t<90. I am using version 2015. The model is a mm part. I get the same error. There is no way the parametric equation editor should choke on this equation. This is an obvious major bug in the parametric equation editor. Has Autodesk fixed this yet?
