Enveloping or Globoid Worm Gear Help
Hi there,
I am trying to generate an enveloping worm gear assembly using the Worm Gear Generator Dialog box. The autodesk knowledge/help section states globoid (enveloping) worms can be made but doesn't elaborate on which parameter to be use. I have tried a number of things but have gotten stumped, has anyone tried this or able to give some insight into what I need to be looking at in the dialog box?
Heres the link to the knowledge section:
http://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/201...
Thanks and look forward to any assistance,
David
Can anyone take a look at this, its been over 3 years! I have also recently needed to design these gears and its a nightmare! Please send help!
@Anonymous wrote:
Hi there,
http://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/2016/ENU/Inventor-Help/files/GUID-8A702F74-B60D-405C-9B5C-769D378EFA41-htm.html
David
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Without more details or an example of what you are trying to accomplish it may be difficult to point you in the right direction.
If you could supply your attempt that would be helpful for inspection and forum experts to comment further.
Please select the Accept as Solution button if a post solves your issue or answers your question.
jan.vonasek
calculated teeth shape and related formulas can be found here https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
Can you please better describe what issue are you facing?
Note: generated 3D models are approximate only, far from real shapes. So, they are applicable only for raw visualization.
Jan Vonasek
software developer
Jan Vonasek
Software Developer
