第 1 条消息(共 5 条)
不适用
10-24-2019
03:30 AM
Evening all,
I am having a box section that in the very top I want to end with 45 degrees angle. So I have my 100x100 box section created by frame generator and I used a extrude cut @ 45. Then I tried to use End cap command to close it but it looks that it doesn't work(attached cut-cap). So then I have tried to cut the frame using the trim/extend with a 45 degree plane (I know that needs a face) (attached trim-extend to plane) even thought in preview you can see the cut when you apply it doesn't actually do anything(attached trim-extend to plane 2). Is End cap suppose to work in angles at all? Any other suggestions that I can try or I need to create a cap part?
Cheers
Y.
已解决! 转到解答。
