Emboss
Emboss
per.widegren
Message 1 of 17
Emboss
per.widegren
Hi Guys,
I´m having problem with the Emboss that it not breaking thru the edge.
maybe I´m using it in a wrong way...
whant to do a Pocket along the surface 0,3mm deep, works brilliant if you stay inside the surface.
Is there another way to do it?
It looks like in the picture
Replies (16)
Message 2 of 17
JDMather
Can you attach the actual *.ipt file here?
What version of Inventor are you using (including Service Pack information)?
Message 3 of 17
per.widegren
Hi JD.
The sketch is going outside the edge,
##- Please type your reply above this line[image: Infogad bild 1] -##Adding
the model as well
Message 4 of 17
JDMather
If you are attempting to add the attachment with the phone app - you will need to use web browser instead.
Message 5 of 17
johnsonshiue
Hi! Without seeing the part, I can only guess. I would say the Emboss was created probably before a few downstream features. It is supposed to go through the edge but the downstream features hold it back. Please attach the file here to confirm.
Many thanks!
Software Test Engineer
Message 6 of 17
per.widegren
Hi Guys,
here comes the IPT file again.
Message 7 of 17
per.widegren
I found a workaround for this problem. But it would be good if I dont need to do that.
The workaround is to cut the surface where the emboss did´t got thru. then it looks like this as it should.
Message 8 of 17
Thomas_Savage
Do the Emboss before the extrude.
Then it will work.
I suppressed your extrude. Did the emboss, then did the extrude, and it worked.
I also suppressed the shell.
I have attached a print screen so you can see, and the .ipt.
You also needed to fully constrain the sketch.
So if you do the Emboss before the Extrude it will work fine.
Thomas.
Thomas Savage
Design Engineer
Message 9 of 17
JDMather
@Anonymous wrote:
I found a workaround....
@per.widegren
You could model this part much more efficiently - from the first sketch to the last feature.
If I remodel the part to demonstrate how - are you going to stick around for the solution, or are you happy with what you have?
Message 10 of 17
per.widegren
Yes please that could be interesting to see 🙂
Message 11 of 17
JDMather
Well, as I started to reproduce this in a more efficient technique (not creating any Workplanes), after Sketch1, none of your sketches are fully dimensioned?  I worked out on the shop floor for 8 yrs and yet I am not familiar with making parts without dimensions.
Can you go though and add your missing size and position dimensions to all of the sketches, not just Sketch1?
Is this a school assignment?
Message 12 of 17
per.widegren
Hi here comes the part with dimensions 🙂
Ye I try to learn how to design this kind of plastic parts. or in general diecast parts. in a more design looking way. Kind of.
Message 13 of 17
JDMather
It appears to me that you simply went through and added a bunch of meaningless dimensions?
I had to put a couple of hours of work into this.
I recommend that beginners give honest effort.
See attached.
Message 14 of 17
per.widegren
That was an intresting way to solve it,
Many thanks  to explane and showing how it can be done 🙂
Regarding the dimension, I didn´t know what you where needing to show how it could be done. so I put some litle everywhare.
Most of the time I never ever use dimension if I don´t really need it.
Those inventor work better in a mathematic way if you fully dimension your models?
Message 15 of 17
Thomas_Savage
When don't you need a dimension?
You should always dimension and fully constrain your sketch.
Thomas.
Thomas Savage
Design Engineer
Message 16 of 17
Bill_Bogan2
The concept of a fully constrained sketch sounds new to you. Here's a brief explanation of why you would want to consider constrained sketch geometry.
An unconstrained sketch is a little like riding a bicycle without using your hands. It can be done, but the slightest bump, rut, or shifted weight can effect your direction and cause you some level of discomfort. It is the same with unconstrained geometry.
A couple of the values of constrained sketches are (there are more):
  • Predictable behavior when you modify a value or relationship
  • They help reduce or prevent unexpected/unwanted changes in model shape, size, etc.
  • You can create relationships between model defining geometry. E.g. a hole being concentric with an arc/cylindrical shape, or an embossed feature maintaining a fixed distance from an edge.
Hope this helps a little.
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
Autodesk, Inc.
Message 17 of 17
Paul.Normand
It's very important to add dimensions and constraints to your geometry so that you do not accidentally "nudge" geometry with your mouse and make an unexpected change.  Are you adding dimensions and then erasing them to clear up the display? The dimension visibility can be turned off manually (View tab>Object Visibility) and dimension visibility is automatically turned off by the system when the sketch is consumed by a feature. Sounds like you could benefit from some training.
Did you know that Inventor comes with many hands on tutorials that include text, video, and datasets? If you are new to 3D modeling software, I suggest checking out the tutorials found in the Learning Path (Get Started tab>Learning Path).
More tutorials on a variety of topics can be found in the tutorial gallery (Get Started> Tutorial Gallery)
Paul Normand
Principal Content Developer/SME
Design Lifecycle and Simulation (DLS)
Autodesk, Inc.
