embedded excel spreadsheets not supported on this platform ??
HermJan.Otterman
Advisor Advisor
HermJan.Otterman
Hello everyone,
Yesterday I tried to open in Inventor part with an embedded excel sheet. Inventor give me this error:
So I tried creating a new part, and a new excel fille:
Then in the part, go to the parameters and embed the excel file in the part
after choosing "Open", I get the Error....
I have both 2017 R2 and 2016 installed and they both give me the same error.
I reinstalled Inventor 2017: same result.
I'm working on Windows 10 with Excel 2013
I asked two colleagues, and they had the same thing.
On the internet I could not find this error....
so is this still working for everybody else?? or has some update broken something?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Roelof.Feijen
I am having the same problem.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
HermJan.Otterman
After creating a case at Autodesk support, they came with this link:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
In my case the variable UseLibXL was already created and had the value of 1.
after removing this variable and a restart, the embedding worked again..!!
(turning the 1 into 0 did not work, I had to remove it.)
Thanks to Hitoshi from Autodesk.
Herm Jan
Hi all,
I'm experiencing the same error message with embedded excel files in Inventor 2016
I've recently created the variable UseLibXL in my system to fix an issue I was having with the thread feature spreadsheet.
(At the time Inventor froze for a few minutes every time I had to create a thread or inserted an iPart that had a thread feature. It was fixed with the creation of this variable).
Now I'm finding that this variable is causing me problems with embedded excel files on my .ipt.?
Is there a solution that allows me to keep both features working properly?
Thanks is advance
Jon
Inventor 2016.2.2
Windows 7 64bits
Microsoft Excel 2013 (Microsoft Office Professional Plus 2013)
HermJan.Otterman
Hello Jonathan,
I thing that Autodesk has to fix this bug.
hopefully will they look into this.
Herm Jan
