Elliptical ends
Elliptical ends
Message 1 of 12
Elliptical ends
Hello.
How to draw elliptical ends?
Replies (11)
Message 2 of 12
Marco.Takx
Witch version of Inventor do you use?
I only have Inventor 2017 installed so if you have a older release you can't open it. 😞
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 12
Actual I have 2016.
Message 4 of 12
JDMather
Can you attach your *.ipt attempt here?
Message 5 of 12
Curtis_Waguespack
Hi a.prokop,
See the example at this link:
http://forums.autodesk.com/t5/inventor-general-discussion/is-it-possible-to-sweep-an-elipse-shape/m-...
I hope this helps.
Curtis
Message 6 of 12
Curtis,
Wow, that is some impressive modeling right there. Why wasn't an ellipse drawn, lines the horizontal plane and the vertical axis drawn, the ellipse trimmed, and the sketch revolved? One sketch, one operation there.
Message 7 of 12
JDMather
@Anonymous wrote:
Curtis,
....and the sketch revolved? One sketch, one operation there.
Create a 2D drawing of your Revolve and compare the views to the image attached by the OP.
I think you will see the problem with Revolve.
Message 8 of 12
salariua
I think he’s into dished end for stainless steel vessels, torispherical, ellipsoid, etc.
Here are some examples:
www.voestalpine.com%2Fdivision_stahl%2Fcontent%2Fdownload%2F4249%2F34326%2Ffile%2FBrochure_Head%26Co...
http://pvtools.weebly.com/uploads/3/7/9/4/37946983/dish_head.pdf
attached is my 2015 attempt; I am not into surfaces so it needs checking by one of these mad geniuses that posted before me to check my model and correct my attempt.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 9 of 12
salariua
here is another example with calculation formulas:
Edit:
the ones I've done so far are circular so revolving the sketch is sufficient but he wants an ellipse at the vessel end. I wonder how would that be manufactured....
Adrian S.
blog.ads-sol.com
Message 10 of 12
https://youtu.be/ACo-WGuie7o
Here is the 2:1 semi ellipsoidal dished ends I use for our vessels. Easiest to set your parameters and make a quick form so the diameter drives the crown and knuckle radius
Message 11 of 12
mrdeanosid,
The trouble is, the footprint/plan/top view of what OP is trying to achieve is elliptical. Not just a straight-up elliptical head, as Curtis reminded me. Check out salariua's model. I thought that was a good way to go about it. I like to "paramater-ize" things, too. Might not be a bad idea for a double-elliptical head template.
Message 12 of 12
Solution Curtis Waguespack is ok.
But there are errors during the use of the shell.
Thank you for your help.
