Electrochemistry
Electrochemistry
jrobrador19
Electrochemistry
jrobrador19
Good day.
I would just like to ask if Inventor is the right software for the following requirements:
Modeling and Simulation Software Incoporating Physical Mathematical Relationships in Electrochemistry, Semiconductor, and Electromagnetics (wave optics)
1) Modelling Software (general capability)
Equation-based modeling (equations already built-in)
Built-in physics-based modeling for Joule Heating, Electrostatics, Electric Currents
Coupling physics from various fields
Ability to import structures from CAD, text, SEM image, movies and other Materials Science imaging techniques
Multi-cores/multi-processor computing
Have ability to create applications for Windows
2) Electrochemistry modeling capability:
Modeling tools for electrochemical cells
Fluid flow and heat transfer simulations
Analyze current density distributions
Model electrochemical reaction kinetics
Simulate tertiary current density distribution
Simulate temperature-dependent ion-migration
Analyze behavior of porous electrodes
Simulate-electrode kinetics
Simulate AC impedance
Easily include supporting electrolyte conditions
Simulate surface catalytic reactions
If Inventor is not the right software for these requirements, what would you recommend?
Jerous
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
swalton
Inventor will work to model the physical shape of all your components.  Inventor is not capable of the electrochemical or thermal simulation you require.  It is limited to linear stress analysis.
I would research the simulation tools and use whatever CAD tool the simulation tool vendor suggests. A quick google search leads to Comsol's package here: https://www.comsol.com/electrochemistry-module.
Try this link from UT-Austin: http://cec.cm.utexas.edu/software
 You will have to write any equations you need to govern the shape of the components.  See http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-8E5C63EA-0540-4EBE-9B17-B8159C7FE40C
You may be able to link the results of your analysis package to the Inventor model, but you will have to develop that solution yourself.  Search on the Inventor API, iLogic, and linking to Excel in the online help link above.
Steve Walton
Inventor 2025
Vault Professional 2025
