Editing inventor 3D annotation arrow size
falanaayokunle73
falanaayokunle73
Good day everyone
Please how do I edit the size of the dimension arrows in inventor 3D annotation. I was able to edit the dimension text but could not edit the arrow size. I mean the 3D modeling interface and not the drawing interface.
Please who can help out with this. Thanks
MrSmithtastic
AFAIK you can edit both the text and arrow size at the same time using the annotation scale tool.
falanaayokunle73
Thank you so much. I will try that.
Gabriel_Watson
It's actually very counter-intuitive, but you need to access those styles from a drawing anyways (pick "All Styles" as your filter in order to see the 3DA ones), save the edits to your library there, then update your styles in the part or assembly:
falanaayokunle73
Thank you so much.
I will try this too.
