Editing Hole Feature Locations - can't seem to add or delete holes
Howdy:
Here's another one that vexes me, editing hole features.
I usually use the feature using a sketch to drive the hole locations, because that's what I'm used to AND I seem to find that existing holes it's either not possible or it's not easy to add or remove holes later.....
But I'm also finding, that I'm having trouble editing hole features with sketches. I think that I've been able to add a new point and hole to a pattern before, but just now, I can't seem to make it work.
I have a concept part, created from another part that has "adaptive" or "incontext" hole locations. I defined them by copying the holes into the sketch by projecting geometry, then placing a sketch point on top of the center point of the projected circle.....
So I saved this part as another part. I unchecked "adaptive". I made a few changes to the part that moved the holes slightly, since they weren't updating.
So I went into the sketch, and deleted the refs from the original sketch points so that I could recenter them and dimension them.
Exit sketch, and the holes did not follow the sketch points. They are still on the projected points.... ARghh
So I edit the Hole Feature, and this is where I'm stumped. In other CAD tools such as Solidworks, the sketch points selected for holes would be shown in the dialong box such that you can deselect them, and pick something else, but that is not the case here. I want to "deselect all" the former locations, and repick the sketch points that are in the right location.
How do I do this?
Now, I know many of you probably do what I've been doing for months, just delete the feature and start over, but this hole is a drill spot face to mark a weld stud location, and I didn't want to mess around with figuring the depth again. I should be able to edit these right?
