Edit Field Text tool is not visible
Guthery1
Guthery1
When I go to edit the text using the Edit Field Text function, Inventor asks like it has opened the tool, but I can't find the tool anywhere to enter my text.
I recently updated Inventor to the most recent version.
johnsonshiue
Hi! Maybe the dialog is displayed in a different monitor. Please make sure the monitor hosting Inventor is the primary monitor. Also go to Windows Display settings and select the recommended resolution and scale. Right-click on Inventor desktop icon -> Properties -> Compatibility -> "Change High DPI settings" -> check both boxes.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Guthery1
I actually did find the text box eventually.  I had to set my scale to as low as I could, they it appeared at the edge of the window.  Not sure why it would be that far outside of the recommended area after installing 2025, but after pulling it back to the middle of the monitor and resetting the scale, I haven't had any issues.
