Dynamic Simulation- Over Constrained
karthur1
Mentor Mentor
karthur1
I have a DS that is giving me the "over-constrained" error.  I cant figure out what I need to do.  Tried all sorts of joints, but nothing I tried has worked.  One problem that I am having is the clevis needs to stay in-line with the cylinder rod through out the travel.  There is a Insert:3 constraint that does this, but when I go to DS, I get the over-constainted error.  If I suppress it, then try to add joints in DS, I still get the over-constrained error.  When you drag the clevis in DS you can see how the clevis stays in line with the cylinder. But, with the over-constraint, the output grapher wont run.
Also when I run the simulation, I would like the clevis to move only .75 in from the cylinder to simulate the stroke.
I am trying to determine the force on the cylinder thru its range of motion.  I have calculated this by hand so I know what it should be at certian points.
Kirk
JDMather
Have you installed all Service Packs and Updates for 2015?
karthur1
Currently at Build 223, Release: 2015 SP 2, Update 2
JDMather
Have you saved all of your parts since the Updates?
Some of your iProperties would seem to indicate - no.
JDMather
Am I missing something?
How can this assembly possible work?  The hydralic mechanism is one part?  No translational motion of the piston rod possible?
JDMather
Maybe something like this is what you are after?
karthur1
I realize there is no rod there.  I didnt think it was necessary.  I thought that I could use a constraint/joint to simulate it.  It looks like you made several changes to the constraints in my model... just so that it will work in DS I suppose.
I'm just having a hard time understand the joints and how to apply them. What I don't get is how my mechanism works in the model, but then when I take it to DS... it fails.
How do I simulate the cylinder stroking out/in and graphing the resultant force at the end of the arm?
