I'm testing a Stewart Platform model using Inventor's dynamic simulation. I'd like to observe all 3 angles of the platform relative to base. Normally, during designing process, I did it using measure tool, but now I'd like to automate it so I can test my construction comprehensively. Is it possible to add it to the output grapher so I can test it in dynamic simulation environment and see how it changes on graph? I searched for any similar problem but I hadn't found anything really.
Thank you for your help.
Solved by jan_priban1. Go to Solution.
not sure if I understand exactly what you asking for, but you can trace just points (trace points) = calculates its position/velocity in time/position. But there is possibility to define equation, so you can define equation for angle you are looking for. See please the attached image
Regards
Jan Priban
Additional idea,
if your mechanism has 1 degree of freedom then define one parameter, create an macro increasing/decreasing this parameter and let angle you interesting in being written/recorded (txt file ...)
In case of DOF = 2 change by macro 2 parameters and so on ...
Jan Priban
Excellent! This is a solution I was looking for. I will trace coordinates of all 4 platform's vertexes and I suppose I can calculate the platform's three angles relative to the base using these coordinates. Thank you very much for your help.
Best regards,
Dawid
