I work in sheet metal fabrication and often take in part-baked designs of complex constructions from clients. I hit a strange "simple" issue that I can't see an easy way of resolving without rebuilding hundreds of parts from scratch. Essentially, the solutions should be simple but doesn't appear obvious.
So I have a STEP file of a large assembly with several parts having an single radius rolled over the entire length. Inventor refuses to Flat Pattern from STEP due to discrepancies in the SW > STEP > Inventor transfer, but that's maybe fine. I also have DXFs of the Flat Patterns from SW.
Now this is where it becomes less clear on how best to proceed. The DXF Flat Pattern outlines have no guaranteed edges that are parallel to the centreline of the bend over the entire part. This one part has a flat top edge which is an outlier, most are a gentle "U" shape of some description. In principle it should be simple; this is a flat pattern with a red bend centreline of a known radius. I just don't seem to find a way to make it happen.
