In a sheet metal part, I have a sketch that is copied to the flat pattern. This sketch contains a pattern of a block. The sketch shows exactly as it should in the flat pattern. I need to export this flat pattern as a DXF. When I save-as DXF and open it up, the DXF only shows the first instance of the block that was placed in the sketch. The only way I can get the DXF to show what I need is if I make multiple sketches and place only 1 block per sketch, and copy each sketch to the flat pattern. I would have to do this hundreds of times to show what I need on the DXF, so obviously this won't work for me. Any ideas if I am doing something wrong or could go about this another way?
