DWG to IPT
nzylstraU4VW7
DWG to IPT
nzylstraU4VW7
Been having trouble taking a 3D DWG from a customer and exporting it to an Inventor assembly with individual parts and solid faces. I am needing to create parts to add and constrain within the assembly. It will pull the DWG into the Inventor program but continues to recognize it as a drawing and contains only lines, no solids. Any help would be greatly appreciated.
TheCADWhisperer
To get solids rather than drawing you must click Options and select Import rather than Open...
Before you do this you should run the List command in AutoCAD and make sure that you have Solids rather than Blocks.
Attach your *.dwg file here if you can't figure it out.
nzylstraU4VW7
It is a Block reference and will not allow me to convert it to a Solid
johnsonshiue
Hi! Another workflow to consider is to use DWG Underlay. Start a new Inventor part -> Import -> select the DWG file -> pick an origin plane and the origin to place the dwg geometry as a transparency. When you need to consume the dwg geometry, create a sketch on a parallel plane -> Project DWG Geometry -> select the needed geometry.
This underlay can also be shown in a drawing view.
Many thanks!
Software Test Engineer
Cris-Ideas
I had a look.
From my experience you will be much better off recreating this from scratch in Inventor.
It is very simple structure, with only few parts.
I recon it will be most efficient overall to just build and not import.
You will end up with much smaller model, that runs much faster and has many additional advantages in inventor as being 100% native.
Cris.
Cris,
https://simply.engineering
admaiora
you can explode the blocks, then import
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
