This drawing was created in Inventor 2016 or 2017. When I created it I had "alternate units" displayed.
I am currently running Inventor 2020 and made some changes to the drawing, including turning off "alternate units". However, the alternate units persist on the hole note even after deleting the hole note, saving the file, exiting the software, then reopening everything and adding a new hole note.
Solved by johnsonshiue. Go to Solution.
Hi James,
Many thanks for sharing the files! I see the behavior. But, there is an explanation. You edited the Dim Style and suppress Alternative Unit for Dimensions, but not for Hole Notes. You will need to select the radio button for Hole Notes and suppress Alternative Unit. This option is note specific. So, you may have Dimension with Alternative Unit but Hole Notes without it. Please try it out and see if it works for you.
Thanks again!
