Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
DWG Export Dateiname wird klein Abgespeichert
Holger_Fen
Holger_Fen
Hallo an die Experten,
seit der Umstellung von Inventor 2017 auf IV2020 haben wir folgendes Problem,
es werden die Dateinamen beim Exportieren von Inventor - Zeichnungen (IDW) in Autocad Mechanical DWG klein Geschrieben abgespeichert.
Beispiel :
Dateiname IDW : DVX-ENG-123456.idw
Dateiname DWG nach dem Speichern: dvx-eng-123456.dwg
Betriebssystem: Windows 10 Prof. Version 1909
Inventor: 2020.2
Vault: 2020
Hat jemand für dies Problem eine Lösung?
johnsonshiue
Hi! I am sorry I cannot seem to reproduce the behavior. Do you export the dwg file manually or you use Task Scheduler?
Many thanks!
Software Test Engineer
Holger_Fen
Die Zeichnungen werden manuell erstellt, sie Bild.
Der Dateiname ist groß geschrieben, nach dem Speichern wird er klein geschrieben abgespeichert.
Danke für die Bemühungen
The drawings are created manually, see the picture.
The file name is high before , after saving it is short .
Thanks for the efforts
liang_chen
Hi, I test it in English and German version of Inventor 2020.2, but I can't reproduce this issue.
Can you please share the dataset to us for further investigation, including the idw; configuration and tempate files ? Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Holger_Fen
Anbei die Dateien / enclosed the file
liang_chen
Thanks for sharing the dataset. I am sorry I still can't reproduce it with the idw files in my side.
Can you please provide more information?
  1. Does this issue happen in all your drawing files or specific dataset?
  2. Can you please check whether it happens when save Inventor file as any other formats, such as PDF?
  3. Is file name correct in save as dialog, or only become lowercase in the output file?
Fred
Fred Chen
SQA Engineer
Autodesk, Inc.
Holger_Fen
PDF kein Problem  / PDF no problem
AutoCAD Mechanical kein Problem / no problem
Inventor 2020.1 speichern unter DWG Problem ! / Inventor 2020.1 save to DWG Problem !
Siehe Bild 1a /  see Picture 1a
Großgeschrieben DWG 2015 / high written DWG 2015
 Siehe Bild 2a / see Picture 2a
nach dem Speichern kleingeschrieben DWG 2020 / after save small written DWG 2020
