DWF export color
DWF export color
mwright1971
DWF export color
mwright1971
When I export to DWF, all color is lost. My computer is the only one that has this problem and we can't find a setting to fix it. We have checked all settings available to change and nothing appears to be different on my computer.
Please see pics.
Inventor view:
DWF view:
Autodesk Factory Design Suite Premium 2015, Autodesk Inventor 2015, Autodesk Design Review 2013, Windows 7 PC
brendan.henderson
Have you tried the Colour dropdown in Design Review?
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
ChadThompsonPE
Community Visitor
Community Visitor
I had the same problem crop up.  The colors worked fine at first, but then for no reason I could figure out, I started getting the monochrome output every time.  Or sometimes a few of the colors would come in but not all.  After a little experimentation, I found that changing the option in the DWF publishing dialog box from Complete to Express seemed to export the colors correctly.  Apparently you lose some functionality (e.g. design views, positional representations), but for my purposes, I'd rather have the colors than those things anyway.  Hope this helps.
