Driving Multiple Sketch Dimensions from a Drop-Down Selection
Doing some very repetitive (and fairly simple) frame members. Before anyone asks, Frame Generator is a no-go, as it is an utterly useless waste of drive space on my computer and I wish they would just yank it from the program (or make it work like a SolidWorks weldment.)
...anyway. Bunch of frame members that need to be notched to fit one another. Shapes are more complicated than square or round tube, so I can't just change one dimension in the extrude to make them fit. Ideally, I would like to be able to select the member I'm notching for in a drop-down and have it drive the sketch dimensions for the cut.
I have an iPart set up for all of the 'base' members (200 some odd similar shapes with different dimensions) which are also all the same ones I'll be notching them for to meet (at different angles, but I can drive that by driving the angle of the work plane.)
I've tried playing around with iFeatures, but only see direct entry as an option when placing the feature.
I don't want to get too fancy with it, but I also would like to start building some automation into my Inventor when I have to do things like this. I understand this is arguably one of the strengths of this software, and want to take advantage whenever I can.
I'd appreciate any input on this. Thanks.
