Announcements
Drawing View Defaults
stephenwilco
stephenwilco
Is there a place to set options Drawing View options (specifically in the "Model/Reference Data" tab in the library sheet format. There are only two users here and I seem to be the defacto admin :).
Thanx,
S
defato admin :).Thankx Sstephenwilco_0-1728570502445.png
stephenwilco
Further searching revealed threads that said a default setting here is not available. Why?
Gabriel_Watson
It's complicated to distribute for many users (registry copy & paste), but with only two you could try changing the settings used during last placing (not editing) a Base View:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Inventor-...
Edit: perhaps the Model tab has no setting available in the registry at all and you cannot change its default.
stephenwilco
I can try that. Registry edits are always a source of trepidation for me :).
Thanx!
stephenwilco
Oh well, "c'est la vie"
CGBenner
"Registry edits are always a source of trepidation for me :)"
😂 Amen to that!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
