Drawing Text Kept Normal Until Reaches Text Box Width Then Squish Stretch Fit
Julian_Kolb
Julian_Kolb
Hallo,
gibt es eine Möglichkeit die Schriftbreite (einzeiliger Text) an einen bestimmte Länge anzupassen?
Ich habe z.B. eine Länge von max. 80 mm für den Text zur Verfügung. Innerhalb dieser Länge sollen nun verschieden Bezeichnungen geschrieben werden können. Die Textbreite soll sich aber nur dann verringern, wenn der Text länger wie die 80 mm werden würde. Bei kürzeren Bezeichnungen soll die Textbreite normal bleiben (NICHT strecken)!
Im AutoCAD geht dies.
Über eine Antwort wäre ich Ihnen sehr dankbar!
mfg
kelly.young has Translated With Google Translate:
Hello, Is there a way to adjust the font width (one-line text) to a certain length? I have e.g. a length of max. 80 mm available for the text. Within this length now different names should be written. The text width should decrease only if the text would be longer than the 80 mm. For shorter names, the text width should remain normal (DO NOT stretch)! In AutoCAD this works.   I would be very grateful for an answer!
admaiora
Hi Julian,
If I have understood..
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Julian_Kolb
Hi admaiora,
thank you for your solution. That's very good for long text.
But is it also possible at your solution to keep the text width by 100% when you have only 2 or 3 letters?
At the moment the text width will increase to 500% or so...
When the text is very long the text width can be reduced to 80% or what ever is needed.
admaiora
No Julian.
You can't
Admaiora
kelly.young
Autodesk Support
Autodesk Support
Hello @Julian_Kolb I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
The best thing to do would be to vote up this idea:
Smart Fitting Text
I have forwarded the request for development to review as I too have a desire for this function. Thanks!
Please select the Accept Solution button if a post solves your issue or answers your question.
Richard_GirtPA7JP
Here for this. Would be nice not to have to babysit the title block if the title is too long or too short for the limited space they go in.
