Drawing Template - Views with Hidden Lines
Good Morning,
I feel dumb but I can't, for the life of me, find the option in the template (styles, etc.) for my company IDW to default to a multiview with hidden lines. Can anyone point me in the right direction? Thanks.
Drawing resources, sheet formats?
I'm not trying to change sheet size. I'm trying to change the default "place view" behavior so it places multi-views with hidden lines showing.
mcgyvr
There is no spot to put select that as default.
But I believe that setting is retained so once you set it it remembers that setting internally in Inventor until changed..
There are numerous things like that in IDW.. thread features/tangent edges/associative check box,etc...
Cadmanto
Are you talking about your initial view coming in showing hidden lines?  That is what you want set?  There isn't a setting for that, but if you place a predefined view set to hidden in your templates that should give you what you are looking for.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
