Drawing Style do not follow my template
Mustang69
Mustang69
I know I had this problem before but could not solve it the same way now
My drawing template has for instance these settings where trailing zeros should no appear
But when I start to make a drawing from a part these tick boxes are now checked suddenly
Project settings are Read Only
Something I have missed?
W.Versin
Edit in Styles Editor what you want, than save it, make sure you tick on 'yes' at 'save to library'.
If you don't save it to the library it your changes are only in the document, if you open new drawing it will have the defaults of the library.
Hope this helps
Mustang69
Thanks it seams to work! 👍
