Drawing representation error/glitch
Message 1 of 11
When moving a drawing around and zooming in/out this glitch occurs.
Replies (10)
Message 2 of 11
andrewiv
What version of Inventor are you running?  What are your system specs? Operating system, graphics card, RAM, Processor.  All of these things are helpful when troubleshooting.
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 11
johnsonshiue
Hi Henrik,
Please make sure all critical Windows updates are installed. Graphics driver is updated. And, applicable Inventor updates are installed.
I believe I have seen this behavior before. This is an Inventor dwg file, right? Somehow there is a corrupted viewport in the paper space. If you have access to AutoCAD, you might be able to purge out the corrupted view port.
Many thanks!
Software Test Engineer
Message 4 of 11
Software:
"Windows 10 Pro for workstation" version 1909 18363.778
Inventor 2020 Professional,  Build 310
All drivers and updates have the latest versions.
Hardware:
HP Workstation Z4 G4
Intel Xeon W-2123 @3.6GHz
Ram 32GB
Nvidias Quadro RTX 4000
Message 5 of 11
mdavis22569
What happens if you copy the views to a new sheet is it still doing it?
Is this an older / migrated template or an original 2020 template?
Mike Davis
Message 6 of 11
Cannot recreate the error and today it stopped.
The issue was happening all Thursday and Friday.
This is a new model and new drawing.
Must have been a rendering error or something.
Message 7 of 11
mdavis22569
Gremlins ....
Maybe a reboot was needed ... hard to say what could have caused it.
Mike Davis
Message 8 of 11
Gremlings you say...
I'll just format the backup server and it will sort it self out then.
Love a quick fix!
Message 9 of 11
mdavis22569
I don't think you need to reformat ...
It might just be that File / PC at that moment.
Also, are you using the certified driver for the RTX4000
Mike Davis
Message 10 of 11
Yes, always certified updates.
Message 11 of 11
mdavis22569
Sounds good ..just wanted to make sure.
Mainly because I see a lot of the Nvidia users have the Geforce Experience installed and are updating their drivers automatically.
See it a few times a week. So it's one of the go to questions for me.
Mike Davis
