Hello all,
I am having difficulties finding any relevant forum posts related to this issue, but is there any way to distinguish between "simple" and "standard" modeled holes within the hole note section of a given dimension style?
To put my inquiry into context: 99% of the "simple" hole features I place in parts are press/slip fit holes for dowel pins, where I'll take the nominal pin diameter and add .0002 for slip fit holes/subtract .0005 for press fit holes. These holes are called out to 4 decimal places on drawings, and with the occasional lengthy hole table it can become an incredibly tedious process to go through and change each individual hole tolerance.
My solution to this issue was to change the tolerance to 4 decimal places for "THRU" holes in my styles library, but this unfortunately applies to all thru holes, both simple and standard holes. Is there any way to isolate "simple" modeled holes and change the hole note tolerance for hole features of this type? I appreciate any help in advance, thanks.
Mechanical Design Engineer
Inventor Professional - Vault
