Drawing, Edit Dim: Model Value
serpennica
serpennica
I noticed this Model Value when editing dimensions.
I am trying to get a total length of dimensions from my drawing.
I have several dimensions to add up. From the drawing, Is there a way to capture the Model value from several different dimensions and add them up.
not much of a programmer, but illogic is easy.
trying to figure out linear feet of walk way, on a crane.
thank you.
johnsonshiue
Hi! It should be doable. Based on Inventor API Help. "GeneralDimension Object" has a property called "ModelValue". It should return the value from the model.
Many thanks!
Software Test Engineer
serpennica
now what, not my skill set.
still struggle with getting the VB started.
I found this in the VB API search, just a bit more that i can work with. need to get back to school for this.modle value API.JPG
Curtis_Waguespack
Hi @serpennica
Here is a quick ilogic rule that will add up the model value of all the selected dimensions. You can just paste this code into a new ilogic rule in your drawing and run it.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Dim uom As UnitsOfMeasure
uom = ThisDoc.Document.UnitsOfMeasure
oSpaces = "         "
Dim oSSet As SelectSet = ThisDoc.Document.SelectSet
If oSSet.Count = 0 Then
	MessageBox.Show("Select at least one dimension", "iLogic", _
	MessageBoxButtons.OK,MessageBoxIcon.Information)
	Exit Sub
Else
	For Each obj As Object In oSSet
		'filter dimensions, ignore other selected entities
		If TypeOf obj Is GeneralDimension Then
			Dim oDim As GeneralDimension = obj
			oValue = uom.GetStringFromValue(oDim.ModelValue, kDefaultDisplayLengthUnits)
			oMessage = oMessage & vbLf & oSpaces & oValue
			oSumTotal = oSumTotal + oDim.ModelValue
	Next
oSumTotal = uom.GetStringFromValue(oSumTotal, kDefaultDisplayLengthUnits)
MessageBox.Show(oMessage & vbLf &  "+  _____________ " & vbLf &  oSpaces & oSumTotal, "iLogic")
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
