In the drawing view attached I want to show the circular centre line through a pattern of 4 holes on a 100mm PCD. My problem is that I don't have a circular feature to select as the centre of the pattern. I tried using the origin axis but that does not work. I eventually created a sketch with a tangent circle in the small square feature, created the PCD circle then, made the sketch circle invisible. Is there an easier way to do this?
