I don't know your other design constraints and assuming injection molding/die casting, but...
Why are you splitting the mold in that direction? It seems like that will produce two mold halves and three slides, with one slide at the parting line.
A simpler tool may be possible by making the parting surface the base of the wedge, and using a single slide to make the round pin holes.
If you are sand casting, then the suggested parting line seems reasonable.
I tend to put my draft features very early in the model tree and add all the fillets and chamfers once the basic shape is established. I will add rounds and chamfers before a shell shell feature if necessary.
Steve Walton
Inventor 2025
Vault Professional 2025
