Double Digit Rev Numbers
As the title states, anyone know a way to set it to double digits?  Presently, after I add a new revision row, I have to go into the iProperties and add a 0 before the single digit revisions.  Some customers like single digits, others like double.
The only post I found with a workaround was for Revit.
Tried searching the IdeaStation as well, but no luck.  I would like to be able to specify before I place the rev table how many digits would show.  Obviously, for alpha characters, this option would not be available.
Would it be worthwhile to suggest?
Curtis_Waguespack
Hi ASI_Aaron,
I'd give that IdeaStation idea a vote.
In the mean time, here is an iLogic snippet that will add the leading zero. You could create a rule with a "before save" event trigger that would catch this for you.
I hope this helps.
Curtis
oRev = iProperties.Value("Project", "Revision Number")
If IsNumeric(oRev) = False Then
	Return 'exit rule
Else
	If CDblAny(oRev) < 10 Then
		iProperties.Value("Project", "Revision Number") = 0 & oRev
	Return 'exit rule
Else
	iProperties.Value("Project", "Revision Number") = 0 & CDblAny(oRev)
Thanks for the code Curtis.  I'll give it a go.
In the meantime, when I get a free minute, I'll post it over on IdeaStation and get back with a link.
EDIT:  Here the IdeaStation link if anyone would like to vote: Double Digit Revision Number
Thanks again Curtis, just grabbed the new code and will play around with it.
