Dome with a rectangle base
Hi everyone,
I am trying to create a dome ontop of a rectangle but i usually use solidworksand not inventor so im not sure how to do this. I have tried the loft tool but i still get edges on my dome which i can only fillet so far before loosing the shape at the bottom.
Replies (11)
JDMather
Attach your *.ipt file here.
Sculpt or Freeform is the easiest way to get this type of geometry.
undefined
It is a vac form shape so it needs to be a smooth domed shape
PaulMunford
Try a loft to point and adjust the curvature to tangent.
You could also try a surface patch.
In either case, extrud a Helper surface, and create the loft/patch using the surface edge instead of a sketch.
This will allow you to adjust the continuity at the base of the done.
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Yes i have tried that but it is more the corners that are causing the issue and creating edges how do i get rid of these but keeping the rectangle?
JDMather
You didn't mention that you are using r2014.
Also, from your SWx training - you should be dimensioning/constraining every sketch.
It will be a while till I have access to my 2014 machine to exactly reproduce your "dimensions", but in the meatime - check out this thread
http://forums.autodesk.com/t5/inventor-general-discussion/smooth-skylight/m-p/2810382/highlight/true...
There is an example file in that thread similar to your design intent.
That example was created in r2011, long before the Freeform tool added to Inventor.
Yes thank you for pointing out my missing dimessions 😕 this is based on another design that needs to be altered into a plain dome so I just wanted to get the technique if you could have a go and give me any more advice i would very much appriciate it.
JDMather
Did you reverse-engineer the example in the other thread that I referenced?
Paul-Mason
Here's my feeble attempt at this, might not be the approach that some would take but its one way of getting there.
A few screen shots and the file
undefinedundefined
undefinedundefined
undefinedundefined
A lot of trial, error and quite a bit of foul language when thing didn't work BUT I think I got there.
Inventor 2025 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
IgorMir
Hi Paul,
Would something like that be of use to you? Please see the attached file. IV2010 format.
Cheers,
Igor.
Web: www.meqc.com.au
WHolzwarth
That's what I could get with a quick-and-dirty attempt of Freeform in 2015.
undefined
STEP attached.
Walter
Walter Holzwarth
Neil_Cross
Lozbeth - Are you saying you need to keep a perfect rectangle shape at the base of the loft? Retaining the 90deg square corners?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
