Do Not Display Thread Pitch
So I can't seem to figure this one out. Is there any way to not display the thread pitch on a drawing?
For example, an M12 tapped hole displays as M12x1.75. If I just want it to display as M12 without the pitch, how do I do that? I feel like this has got to be something super simple that I'm just missing.
Thanks!
Alex
philip1009
Right-Click the dimension and select Edit Dimension Style, this will take you to the Style Library, and it should take you directly to the section that determines the note, you may have to go through a bunch of Hole dim settings by selecting different hole styles from the drop-down.
Cadmanto
Take a look at this thread and see if it is what you are looking for.
https://forums.autodesk.com/t5/inventor-forum/hole-note-without-pitch/td-p/3693828
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
