Dividing splines in points and export
diego_molina
diego_molina
Hello.
I am new in inventor, I used to work in solidworks. I have a cylindrical surface with multiple faces *look image* and I am using project cut edges to get the splines. I need multiple coordinates of the splines, so I can draw the curve in MSFT Excel and make some calculations based on that.
In solidworks, I used segment to get a lot of points of each spline, then used a macro to export the sketch points, I am trying to do the same in Invtor but I am not able to divide the lines. Any suggestions on what workflow should I follow?
Thanks!
JDMather
@diego_molina wrote:
In solidworks,
CSWP here - Attach your *.ipt file here for demo on how to do in Inventor.
diego_molina
@JDMather Thank you, see attached.
diego_molina
@Anonymous I tried making a rectangular pattern with the direction of a spline but the points are not coincident with it.
diego_molina
@JDMather I created the points but as work features, not in a sketch, any Idea of how can export that coordinates? Thanks!
johnsonshiue
Hi! There is an app to export points.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=346499333339069618&appLang=en&os=Win64
Many thanks!
Software Test Engineer
