@kadscad wrote:
here is a simple solution that could be added. This is from another cad program
Microstation, like AutoCAD, can do that because there are no constraints involved. You can change the snap divisor as many times as you wish, and the placed geometry never moves. The snap divisor in those programs enables precise placement of geometry to those points, but there is no constraint holding them there. They stay there because that's where they were placed. If you move the arc, the lines stay right where you originally put them.
That's not how Inventor (nor SW, SE, etc.) works. What you're asking for is a new kind of sketch constraint, one which would be useful on occasion, I'm sure. But how do you expect these lines to behave if the arc is modified or moved? They should stay connected to it, and remain equally spaced, right? And you should be able to change the snap divisor so the number of segments increases or decreases?
I think an enhanced sketch pattern tool could probably accomplish what you're asking; the Pattern tools for part features can follow paths and space a certain number of features along the length of the path.
But it's possible that your modeling task could be done in a completely different way, maybe even a better way. Feel free to post here and see if anyone can help you out.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
